aalexandrebeta
May 20, 2016Master
Cable modem router French compatible and availability
I am currently seeking to go from DSL to Fiber in France on Orange ISP. I was wondering if I could purchase Netgear equipement to run instead of the orange crap stuff they are forcing us to use! I ...
- Jul 18, 2016
Hello aalexandrebeta
Ask if they support customer owned modems and if so what ones are recommended also make sure its a coax cable connection they use.
DarrenM
DarrenM
May 25, 2016Sr. NETGEAR Moderator
Sorry but we do not sell Fiber modems but you can always use there modem and get a separate router.
DarrenM
- aalexandrebetaMay 25, 2016Master
May I purchase a C7000 and use it in France?
Would it be compatible with their crappy norms and their ISP habbits!
- DarrenMMay 27, 2016Sr. NETGEAR Moderator
Aalexandrebeta
You would have to check with your ISP if that would be compatible are you getting a cable connection or a fiber connection?
DarrenM
- aalexandrebetaMay 28, 2016Master
I'll study the thing with my crappy ISP.
