aalexandrebeta
May 20, 2016Master
Cable modem router French compatible and availability
I am currently seeking to go from DSL to Fiber in France on Orange ISP. I was wondering if I could purchase Netgear equipement to run instead of the orange crap stuff they are forcing us to use! I ...
- Jul 18, 2016
Hello aalexandrebeta
Ask if they support customer owned modems and if so what ones are recommended also make sure its a coax cable connection they use.
DarrenM
aalexandrebeta
May 25, 2016Master
May I purchase a C7000 and use it in France?
Would it be compatible with their crappy norms and their ISP habbits!
DarrenM
May 27, 2016Sr. NETGEAR Moderator
Aalexandrebeta
You would have to check with your ISP if that would be compatible are you getting a cable connection or a fiber connection?
DarrenM
- aalexandrebetaMay 28, 2016Master
I'll study the thing with my crappy ISP.
- aalexandrebetaJul 16, 2016Master
Witch questions do I have to ask to my ISP to check the compatibility with Netgear hardware?
- DarrenMJul 18, 2016Sr. NETGEAR Moderator
DarrenM
- aalexandrebetaJul 19, 2016Master
Thanks a lot because in France those ISP are driving me nutts!
They always oblige you to use their crappy devices!
Why can't a regulator oblige them to let users use or not their crap and standardazie their protocols!
Anyway thanks!
