Farrah
Mar 11, 2017Aspirant
cable modem router model C3700 will only connect to my laptop
I get the message: You are not connected to your Routers WIFI network. To access routerlogin.net your device must be connected to your Router's WIFI network. Check your current connection and try ag...
DarrenM
Mar 15, 2017Sr. NETGEAR Moderator
Hello Farrah
Try to remove the coax connection from the modem and then do the factory reset then try to setup the wireless. After that try to plug into the coax.
DarrenM
Farrah
Mar 15, 2017Aspirant
another thing, when I turn on a wireless device, it shows Neatgear34 and Netgear34-5G. The password works for both, when I use the WPS it picks up the Netgear34-5G and that has a weird IP address and MAC address. From my understanding the modem thinks there is another router and there for is defaulting to router mode off. I have deleted all the networks from my devices and used just Netgear34, but still no connection.
- DarrenMMar 17, 2017Sr. NETGEAR Moderator
Hello Farrah
You also may want to check with your ISP if something is not coded correctly on your account it could disable the wireless.
DarrenM
