kpowe
Apr 04, 2017Aspirant
cable modem setup
Hello, I recently purchased the CM400 cable modem and had it activated with my cable company. After activating the modem, I connected the ethernet cable from the modem to my wireless router. Everythi...
VE6CGX
Apr 04, 2017Master
When it is running Light color signifies whether you are running at 100mbps, of 1000mbps(1Gigabit per ssecond) speed. What is your modem specs?
kpowe
Apr 05, 2017Aspirant
Thank you VE6CGX for your reply. How would I go about locating this information?
- DarrenMApr 11, 2017Sr. NETGEAR Moderator
Hello Kpowe
Here is the user manual.
http://www.downloads.netgear.com/files/GDC/CM400/CM400_UM_17July2015.pdf
DarrenM
