landenlabs
Jan 28, 2023Aspirant
Cable Modem Wifi Router with SNMP
Which cable modem Wifi Routers supports SNMP ? Based on a previous post the SNMP is only available to ISP on the AC1900 C700. I don't understand why the router supports SNMP but it is then blocked ...
Jan 29, 2023Guru - Experienced User
SNMP tends to be more business class products and not consumer products.
Not sure if you'll find anything from netgear on the consumer side supporting it for modem/router.
Why not just get a modem only device and setup your own router that supports snmp.
- landenlabsFeb 02, 2023Aspirant
I use the SNMP to monitor the load on the router via my smart phone.
My cheap TP-Link Archer C50 V5 supports it.
Seems like a simple enough feature to allow for easy remote monitoring.
