Jeannette1's avatar
Jeannette1
Cable Modems
I want to dump Mediacom cable modem.  I currently have Netgear AC1200 Router and have checked CM1000 modem. Will it work w/separate phone modem?  Mediacom bundle phone, wi-fi & cable.  Their Cisco m...
  • FURRYe38's avatar
    The CM1000 only has 1 port. That connects to a external wifi router, such as you Netgear AC1200 Router. To connect additional wired devices you should connect then to the back of the Netgear AC1200 Router. If you don't have enough ports behind the Netgear AC1200 Router, then attach a Netgear GS-108v4 series LAN switch to provide additional LAN ports:
    https://www.netgear.com/support/product/GS108.aspx
