Vso316's avatar
Vso316
Follower
Apr 19, 2020
Can’t connect to my N300 WiFi router (Model WNR2000v5)
I connected my router to the modem. All of the lights are green and I was able to connect my iPhone earlier today when I initially activated my xfinity service. Now, I can’t connect at all. I tried using my wife’s iPhone and it won’t connect either. I tried turning off the router and turning it back on but no luck.
  • plemans's avatar
    What xfinity router are you connected to? (model)
    running 2 routers on the same network puts you in a double nat. If the xfinity device is a modem/router combo device, the xfinity either needs to be put in passthrough mode or the netgear in AP (access point) mode.
    • Shawn_171992's avatar
      Shawn_171992
      I had that same issue. I upgraded to the nighthawk ac1900 modem router & now my speeds have doubled!
      • plemans's avatar
        The OP might even see better gains depending on their service. The wnr2000 is a pretty old N300 single band 10/100mbps device. pretty base level router even when it came out.
