ccislander's avatar
ccislander
Can C7000 modem/router serve as base for Arlo security camera?
I'm looking to purchase some Arlo cameras but am trying to determine if I need the Arlo base or if I can purchase add-on cameras and link them directly to this router.  I read the R7000 can serve as a base for the Arlo cameras, eliminating the need for a separate base.  I'm wondering if the C7000 can-do the same.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello ccislander
    No the C7000 can not act as a base for the Wire free arlo cameras you would still need the base station in order to use them.
    DarrenM
    • seabaughs's avatar
      seabaughs
      Can I use Readyshare (a thumbdrive) to store video from my Arlo cameras instead of a cloud service ?
      • DarrenM's avatar
        DarrenM
        No you can not arlo is a cloud service and some cameras have local storage via sd card.
        DarrenM
