Auldphart
Apr 30, 2016Aspirant
Can I use The AC-1900 as a router only?
I use the AC-1900 on Comcast in Florida. I trying to use it with Rogers in Ontario but they won't authorize it for direct connection, you have to use a Hitron gateway supplied by them. Can I put the ...
- May 01, 2016
I was mistaken. The C7000 cannot be used solely as a router. I was thinking of the D7000.
TheEther
Apr 30, 2016Guru
Yes, you can use the C7000 solely as a router.
