Auldphart's avatar
Auldphart
Can I use The AC-1900 as a router only?
I use the AC-1900 on Comcast in Florida. I trying to use it with Rogers in Ontario but they won't authorize it for direct connection, you have to use a Hitron gateway supplied by them. Can I put the ...
  • TheEther's avatar
    TheEther
    May 01, 2016
    I was mistaken.  The C7000 cannot be used solely as a router.  I was thinking of the D7000.
