mspuckit
Mar 25, 2016Follower
Can my C6300 be used as an access point on Verizon Fios?
Hello,
I have a C6300 with Firmware V1.02.19. I will be leaving TWC soon and switching to Verizon Fios. Can i use this as an Access Point on the verizon network? I don't see an actual setting to turn AP on?? Am i missing something? I was really hoping i would be able to use this router for extending my wi-fi.
thank you,
J
- netwrksMasterYou can turn any wifi router into an AP. Here's a link that describes generically, modifying wireless router to AP. - netwrks is correct. To clarify the conventions used by Netgear and on this forum, an Access Point (AP) requires a wired connection (typically Ethernet or Powerline) back to the router. This is not to be mistaken with a wireless range extender (aka repeater). All Netgear routers can function as APs, but they make poor wireless range extenders. - For the benefit of other readers, the link provided by netwrks is what I call the old school method of converting a router to an AP. IMO, it's a superior method than the AP Mode setting offered on some models. The old school method sacrifices a LAN port but wired speeds are often much faster because it avoids potential bottlenecks between LAN and WAN ports.
