rupampaul's avatar
rupampaul
Can not connect to 5G
I am not able to connect any device to 5G. Tried rebooting, factory resetting, and changing channel, but the problem remains.
But all device gets connected to 2.5G easily.
Request suggestions and help.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Are you able to see the 5 ghz network?
    DarrenM
    • rupampaul's avatar
      rupampaul
      5GHz network is available. But it does not allow any device to join. Even if a device joins the network, internet is not available.
      Rupam
      • FURRYe38's avatar
        Sounds like the modem is faulty. Needs to be reviewed by NG support or just replaced.
        Rupam
  • FURRYe38's avatar
    Any progress on this?
