62BT409's avatar
62BT409
Follower
Mar 31, 2019
Can not get into my C6300-100NAS
I have typed both the items in the brower that is nneded, then hit the enter key. It drops the "http://" and tells me
"This page isn’t working
routerlogin.net sent an invalid response.
ERR_INVALID_HTTP_RESPONSE"
I have come to realize that it is a bug in my system and can not come up with a finding. So any help or ideas would be appreicated.
THX
  • > I have typed both the items in the brower that is nneded, [...]
       Which would be what, exactly, in your opinion?
    > [...] then hit the enter key. It drops the "http://"
       "hides" might describe it better than "drops".
    > and tells me [...]
       Your Web search for terms like the following found nothing useful?:
          netgear ERR_INVALID_HTTP_RESPONSE
    > [...] So any help or ideas would be appreicated.
       Use a web browser other than Chrome (at least until Netgear updates
    its firmware for your device)?
  • plemans's avatar
    you can try logging on via the IP address. Default is usually 192.168.1.1 or 192.168.0.1. but you can find it by this option:
    https://www.howtogeek.com/233952/how-to-find-your-routers-ip-address-on-any-computer-smartphone-or-tablet/
    Once you have that address, type it into your browser and it should bring you to you're devices page.
    here's a specific manual for the C6300-100nas
    http://www.downloads.netgear.com/files/GDC/C6300/C6300_UM_17Nov2015.pdf
