SW2424's avatar
SW2424
Follower
Dec 23, 2015
Can not reset N300 Model C3000 to factory settings
have never changed factory settings, can't login with user: admin and password: password
also cannot reset N300 Model C3000 to factory settings
have held the reset button on bottom as described in manual, has no effect.
any suggestions?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Sw2424
    If the factory reset is not working might be out of luck no other way to reset the login. If the modem is still under warranty contact netgear phone support see if it can be RMA
    DarrenM
