Retired_Member
Mar 25, 2019Can someone please explain to me the difference between these two switches GS305 and GS105NA?
Hi, I'm looking for a 5 port switch and I found two models from Netgear that I'm interested to use at my home with my desktop, Nvidia Shield, etc... I looked the specs and my non-technical expertise doesn't help to differentiate both. Could someone please highlight what is so different between the GS105NA and the GS305?
Is the difference that the GS105NA can connect up to 2gibit per port and the GS305 only makes up to 1gbit?
> [...] I looked the specs [...]
Which "the specs"? Visit http://netgear.com/support , put in your
model number(s), and look for Documentation. Get the Product Data
Sheet(s).I don't see any significant differences. Length of warranty?
> and the GS305 only makes up to 1gbit?No. Both have 1Gb/s ports.
There's a more appropriate forum for such devices:
https://community.netgear.com/t5/x/bd-p/business-unmanaged-switches
- Retired_Member
Thank you for pointed the appropriated space for this discussion.
