joshglass1
Nov 10, 2016Aspirant
Can the CM500 be used for Verizon Fios Service
Quick question for everyone out there. Does anyone know if the CM500 can be used for Verizion Fios internet service? I am getting the service turned on soon and I don't want to buy another modem if...
DarrenM
Nov 14, 2016Sr. NETGEAR Moderator
Hello joshglass1
No the Cm500 only supports cable connections I believe you will have to use verizons provided modem.
DarrenM
- joshglass1Nov 14, 2016Aspirant
DarrenM,
Thanks for the reply. I honestly forgot that I had posted this or I would have updated. I spoke to Verizion and this model will infact work just fine. I'll keep this updated in the event that something happens and this turns out to be untrue. I should fine out tomorrow.
