Scrotty68's avatar
Scrotty68
Follower
Dec 28, 2017
Cannot connect using ethernet conection
I recently purchased my own modem (CM700) and a wifi router (N750 wireless dual band) in order to have better service and save money. I am also supplementing the above with a few network switches (GS105), all Netgear products.
With the exception of the new products, nothing else has changed, network wise. However now I am unable to Lan wire my 2 Samsung Tvs, my home security system and my PS4!
I have done all the troubleshooting techniques and still nothing. I am hoping someone will have an answer.
Thanks in advance,
Sean
1 Reply
  • > [...] a wifi router (N750 wireless dual band) [...]
       "N750" is a speed, not a model number.  Ever helpful, Netgear product
    packaging emphasizes speeds like "Nxxx", but that's not the model
    identifier.  Look at the label.
    > [...] all Netgear products.
       Swell.  How are all these things connected?
    > network wise.
       I'd say that a new modem and a new router would be enough changes to
    make some difference.
    > [...] now I am unable to Lan wire my 2 Samsung Tvs, my home security
    > system and my PS4!
       "I am unable" is not a useful problem description.  It does not say
    what you did.  It does not say what happened when you did it.  As usual,
    showing actual actions with their actual results (error messages, ...)
    can be more helpful than vague descriptions or interpretations.
       That non-description conveys no useful information about what you did
    or what happened when you did it.  Do the LED indicators on these
    devices indicate anything?  If you connect a computer directly to the
    CM700, can you communicate with its management web site?  And if you do
    the same thing with the (unspecified) router?
       In general, you might start with getting the modem connected to your
    (unspecified) ISP.  When that works, add the router, and deal with that.
    When that works, start adding other devices.
       If you don't already have the User Manuals for these devices, then
    visit http://netgear.com/support , put in each model number, and look
    for Documentation.  Get the User Manual(s).  Read.
