serialnick
Dec 23, 2016Initiate
Cannot figure out how to factory reset C3000 router
This is a wireless n300 router with model number c3000 running on Windows 10. Somehow i've managed to mangle the admin password for router login (note: NOT the wifi password--i'm up and running with ...
- Dec 29, 2016
Hello serialnick
The reset button may be located on the bottom of this modem should be a small pin hole.
DarrenM
DarrenM
Dec 29, 2016Sr. NETGEAR Moderator
Hello serialnick
DarrenM
serialnick
Jan 04, 2017Initiate
Right you are! Thanks!
