Oldsam
Oct 09, 2017Follower
Cannot find Firmware Update or Router Update button on N600, C3700 WiFi cable modem router
Hello, On Oct 5, '17 I received an e-mail from NetGear advising me to upgrade the firmware on my N600-c3700 router to fix a security issue. It asks to log into the router, select Avanced Administrat...
antinode
Oct 09, 2017Guru
> How do I update the firmware?
Most likely, you don't.
Cable TV ISPs generally want to control the firmware on cable modems
which are connected to their networks, so you may not be able to update
the firmware on your cable (TV) modem. The ISP can do it.
If the folks at Netgear who are in charge of these notifications were
even minimally alert, then they might not be bothering users who have no
control over their firmware. Unless their scheme is to prod users into
complaining to their ISPs about it. Seems unlikely, though.
