Oldsam
Oct 09, 2017Follower
Cannot find Firmware Update or Router Update button on N600, C3700 WiFi cable modem router
Hello, On Oct 5, '17 I received an e-mail from NetGear advising me to upgrade the firmware on my N600-c3700 router to fix a security issue. It asks to log into the router, select Avanced Administrat...
tkhula
Oct 28, 2017Tutor
I have the same issue for which I recieved the standard bogus incorrect answer from Netgear which only serves to remind me WHY I DON'T USUALLY BUY NETGEAR. I have the identical issue and my question was closed. I can't find my question so I hope you don't mind that I'm joining yours. The controlled by your ISP does not apply to mine - My model is the C6250-100NAS and it is MINE. Bought by ME. IF you purchased yours yourself then I feel your pain. My version of the firmware is vulnerable but for the EXACT same reasons can not be updated. The option has to be there in order to update folks. I hope you have better luck than I . I'm going to have to pitch this router and go with ASUS or someone else as soon as I have money to spend again.
BELOW IS EMAIL I RECEIVED.
Hello ${recipient.login},
A reply to a topic you are following has been accepted as a solution!
| Topic: | ${thread.topicMessage.subject} |
| Author: | ${thread.topicMessage.author.login} (${thread.topicMessage.author.ranking.name}) |
| Date: | 2017-10-20 11:47 AM |
Hi @tkhula,
You may refer to the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
Also, please make sure a factory reset is done after updating the firmware. The steps are linked below.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
To manage your notifications, click here.
If this link doesn't work:
- Log on to NETGEAR Communities.
- Click My Profile.
- Click the Subscriptions & Notifications tab.
- Change your settings and click Save Changes.
Thanks for being a NETGEAR Communities member.
Your NETGEAR Communities Team
NETGEAR Communities sent (censored by me)
Don't want to receive emails from us? Just click here
- antinodeOct 28, 2017Guru
> [...] I can't find my question [...]
This one?:
https://community.netgear.com/t5/x/x/m-p/1400638
I clicked on your user-ID to find that.
> [...] I have the identical issue [...]
This seems to be a non-standard meaning for "identical". This thread
began with a question about a C3700, a cable-TV modem+router.
> My model is the C6250-100NAS and it is MINE. [...]
Ok, but the other thread (yours) referred to an "R6250", which is not
a cable-TV modem+router. If you really have a C6250, then it may not be
amazing that a response tailored to an R6250 would be less than
satisfactory, but it's not immediately clear that Netgear is the cause
of that dissatisfaction.
> The controlled by your ISP does not apply to mine [...]
For a cable-TV modem(+router), the question is not who owns it, but
to whose network it's connected, as explained above.
> [...] My version of the firmware is vulnerable [...]
Says who?- tkhulaOct 28, 2017Tutor
AHA! well.. A: I clicked the icon, looked at the account stuff but now I know to click the name thing. I was totally unaware of that so thanks!
B: The other thing was a clear mistake (C6250 is right, R6250 is not. I had issues finding it on the list and the photos of them are identical. I would have sworn to you that I got the original model directly from the router-beast itself but.. yes.. oops )
As a result I was responding to: https://kb.netgear.com/000049498/Security-Advisory-for-WPA-2-Vulnerabilities-PSV-2017-2826-PSV-2017-2836-PSV-2017-2837
However, I still have no solution to updating firmware and I'm not really confident with hardware that does not have a firmware update path.
If you see anything else I missed, I'm good with you pointing it out. I just want to update it if it needs. I have a very very mixed household with 5 android devices, 2 pieces of fruit and 5 PC's.
Ideas?
> As a result I was responding to: [...]
NETGEAR is aware of WPA-2 security vulnerabilities that affect
NETGEAR products that connect to WiFi networks as clients. [...]
o Routers and gateways are only affected when in bridge mode
(which is not enabled by default and not used by most
customers). [...]
These WPA-2 vulnerabilities affect the following products:
Is your C6250 a wireless client? No, it includes a wireless access
point to which other (client) devices connect.
Is your C6250 a router operating in bridge mode? The only bridge
mode I see in the C6250 User Manual is for a modem-only mode, which is
not the kind of _wireless_ bridge to which the Security Advisory refers.
So, no.
Is your C6250 on the list of vulnerable devices? As with all other
cable-TV modem(+router)s, no. It can't be a wireless client device, and
it can't operate as a wireless bridge (where it would act as a fancy
kind of wireless client device).
> path.
It's a cable-TV modem+router. The cable-TV ISP controls its
firmware. It has a firmware update path, but it's largely out of your
control.
> Ideas?
Don't worry, be happy?
