Oldsam
Oct 09, 2017Follower
Cannot find Firmware Update or Router Update button on N600, C3700 WiFi cable modem router
Hello, On Oct 5, '17 I received an e-mail from NetGear advising me to upgrade the firmware on my N600-c3700 router to fix a security issue. It asks to log into the router, select Avanced Administrat...
antinode
Oct 27, 2017Guru
> As a result I was responding to: [...]
NETGEAR is aware of WPA-2 security vulnerabilities that affect
NETGEAR products that connect to WiFi networks as clients. [...]
o Routers and gateways are only affected when in bridge mode
(which is not enabled by default and not used by most
customers). [...]
These WPA-2 vulnerabilities affect the following products:
Is your C6250 a wireless client? No, it includes a wireless access
point to which other (client) devices connect.
Is your C6250 a router operating in bridge mode? The only bridge
mode I see in the C6250 User Manual is for a modem-only mode, which is
not the kind of _wireless_ bridge to which the Security Advisory refers.
So, no.
Is your C6250 on the list of vulnerable devices? As with all other
cable-TV modem(+router)s, no. It can't be a wireless client device, and
it can't operate as a wireless bridge (where it would act as a fancy
kind of wireless client device).
> However, I still have no solution to updating firmware and I'm not
> really confident with hardware that does not have a firmware update
> path.
It's a cable-TV modem+router. The cable-TV ISP controls its
firmware. It has a firmware update path, but it's largely out of your
control.
> Ideas?
Don't worry, be happy?
tkhula
Oct 27, 2017Tutor
Not happy - no the ISP does not control firmware or programming on a privately owned device. I'm lucky my isp could follow MAC address instructions. My issue is lack of updating capability. If it's something I can push.. then I want that line of code so I can do so should it be needed.
