Jccasey22's avatar
Jccasey22
Follower
Dec 16, 2021
Cannot reach 1 website only
I am unable to reach one website only, my company's website, at this time. I have done a full factory reset on my NightHawk AC1750 C6300v2 as well as several full resets of my computer. I am using Chrome on macOS. This issue has come up before, but usually only lasts a few minutes. It has been blocking my access to my website for a full 24 hours now.
I have changed DNS settings, and cannot find a way to see if this is a firewall situation within the Nighthawk app or in the advanced settings on netgear.
To make sure it wasn't a wifi issue or a mac issue, I have plugged a separate PC into the ethernet cord and have the same issue.
The website is working find and is accessibel to my entire team, and also works fine if I access it through my data plan.
Is this a faulty router issue?
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
    What happens if you put your mac IP address into the modems DMZ?
    What happens if you intput custom DNS into the modems Advanced tab/Setup/Internet section? Try Google or Cloudfare DNS addresses here.
    Thank you.
  • FURRYe38's avatar
    Any progress on this?
