jadedthang
May 26, 2019Aspirant
Can't connect gaming consoles or Amazon Echo Dots via wifi on C6300
Model Version: C6300
Firmware Version: 2.01.26
OS: Windows 10
ISP: Cox
I can connect my pc's, laptops, and cell phones to wifi with the C6300, but I cannot connect PlayStation 4, Xbox One, or Nintendo Switch. Nor can I connect the Amazon Echo Dot. It's mostly giving me DNS errors. I'm also having problems connecting to the router admin site, and the Genie app. Logging in is sporadic at best with the app on my phone (repeatedly keeps telling me to connect to my router's wifi), and going to routerlogin.net or .com just gives me "routerlogin.net sent an invalid response." Using 192.168.0.1 will occasionally let me use the Netgear genie config site.
Any helpful tips on what settings I need to change, or a direction to point me in trying to troubleshoot this?
How are you trying to connect the game consoles? Wired or wireless?
- jadedthangAspirant
Connecting wirelessly.
Any Wifi Neighbors near by? If so, how many?Whats the distance between the modem and these consoles?
Do they connect wired to the modem?
