yaboy_713
Dec 14, 2017Follower
Can't connect to my C7000
Hello Guy's, I'm trying to connect to my router from an outside connection via the IP address given through the router. When I try to connect through my T-Mobile hotspot, it does not connect. When I...
William10a
Dec 14, 2017Master
http://www.downloads.netgear.com/files/GDC/C7000/C7000_Comcast_UM_27apr15.pdf
Here is the link for modem/router, the C7000 has no wan(internet) to connect too.
It only has a tv cable connection port for the tv cable from your cable provider, you may need to get a router without a modem in it to connect your device to a router to use it in your home as your main internet source.
Sorry but it is not the C7000 fault it is made for a different job then you want it to do.
If it were a R7000 it may work but not a C7000 cable modem/router the R7000 is just a router without a modem.
