ultranothing
Mar 16, 2026Tutor
Can't get over about 200mbps on new CAX30 with Xfinity 1.2gbps plan
Hi! I've got a new Netgear Nighthawk AX6 CAX30 with firmware 2.2.4.2. I have the Xfinity 1.2gbps plan. On my PC I'm seeing speeds of about 200mbps. On the PC's 2.5G connection I'm seeing...
Mar 16, 2026Guru - Experienced User
FYI, the LAN ports on the CAX30 are only 1000Mpbs supporting so max you would see would be around 900Mpbs at most. You won't see anything over 1Gb.
Brand and model# of the ethernet adapter in these PCs.
WiFi Channels configured on the CAX30 for wifi?
Armor, Smart Parental Controls or Circle, IPv6, Protection Engine, Traffic Meter.
Please post a copy and paste of the modems connection status and event log page.
- ultranothingMar 16, 2026Tutor
I cannot seem to reply to you with the information. When I click "Reply" it kicks me back to the conversation and the message hasn't posted. I'm not even sure if this message will post.
- FURRYe38Mar 16, 2026Guru - Experienced User
Got it.
