    • ElaineM's avatar
      ElaineM
      NETGEAR Employee Retired
      Hello V2philips
      Are you just having problems with the WiFi?
      Do you still have internet access through wired connection?
      Make sure that the SSID broadcast on the unit is enabled.
      In order to check this setting, you will need to access the admin page of the router.
      See the same instructions on this link on how to get into that window.
      By the way, do this on a computer that can get online.
