Jul 01, 2015Follower
Can't log in to router with admin
I bought a new cable modem router six months ago to stop the modem rental fee from Time Warner Cable. I got the C3700 model to replace our old router. I set it up with a new wifi password and a new admin password to access the router control panel. No problems. Internet access still works for both wifi and ethernet and the router still asks for the wifi password when a new device connects to the wireless network.
However, I can't log in to the admin control panel now. I remember the admin password and even had it written down in a safe place. The password doesn't work. I tried the default admin/password as printed on the router but that doesn't work either. There isn't a "restore factory settings" button on the router. What can I do to log in to the control panel?
- Babylon5NETGEAR Employee RetiredWas the new router supplied by TWC?
Page 99 of the router manual suggests that there is a factory reset button recessed in the bottom centre of the router;
http://www.downloads.netgear.com/files/GDC/C3700/C3700_UM_21Aug2014.pdf
But before you do this, just on the off-chance that you have a keyboard issue, type your password into a plain text box, e.g. notepad, or just type it in the User ID field. Clutching at straws there, but it does happen.- MuddlesAspirant
Yeah! It seems to be working now. After studying the manual last night and trying a few things this morning. After I did a complete reset and it worked for me. My Genie looks a little different but it's working.
