Carijit's avatar
Carijit
Cant Login Back after C7000v2 reset
Hi,
Had to reset my c7000v2; but after the reset, I cant get into the router/modem. The 192.168.0.1 aaddress is not pinging, I connected a cable to my laptop but it was unable to receive any IP; provided an static IP  192.168.0.222; still no luck. The default NETGEAR24 SSId is also not visisble ..
Appreciate any help in advance.
Ari
  • FURRYe38's avatar
    Pressing the reset button for 15 seconds then release the wire connect the PC to the modems LAN port and open a web browser to 192.168.0.1 or 192.168.100.1 doesn't result in anything?
  • plemans's avatar
    what are all the lights on it doing?
    Try resetting it but unhook the coax from it. unhook coax and push reset for 7-15 seconds while its powered on.
    then try going through reset again.
