Ricamiller's avatar
Ricamiller
Can't login to router Netgear CMD31T
Hi there, I reset the password on my router and now it will not let me login using the new password or the old password.   I reset the router several times to factory defaults but still can't logi...
  • Ricamiller's avatar
    Ricamiller
    Feb 26, 2020
    Hi there,
    I turned the modem off, unscrewed the coax, turned the modem on, let if fully boot up, pressed and held the reset button, let it fully boot again, tried to login with another computer using admin password and it would not accept it.
    So, I tried the MSO trick and was successful. I went into the interface and clicked on "reset factory settings", rebooted and boom - logged in using admin password.
    I see now that there is way to update anything which is all I wanted to check in the first place. So I am done.
    Thanks for trying to help.
    Ric
