DocRockk
Nov 18, 2017Aspirant
Cant Login to Router/Modem after factory reset
I somehow lost my wireless connection on the router early Friday am, been troubleshooting since with no luck! Tried all the info in articles posted here about not accessing the router after a reset.
After now doing several hard factory resets, I still cannot access the router login page on any browser, using the standard "routerlogin.net & .com, or the standard "192.168-0.1 (or 1.1)" addresses, which "cant be reached". The "routerlogin.net/com" addrsses show up every time as..."You may not be connected to your Router’s WiFi network. To access routerlogin.com, your device must be connected to your Router’s WiFi network. "
The odd thing is that I AM able to connect to the Netgear Web Based Gateway Configuration Utility (not the Router's normal congfiguration settings), when I login to 192.168.100.1 Here I see a the Genie inteface, but cant do much of anything (see attached screenshot).
So I finally call Net Gear Tech support and eventually am told that for $50 they will do a one time remote fix. The Rep indicated that "my IPv4 ip address of 80.50.254.105 was a "public" IP and that it needed to be a "private" IP for be to be able to login to the router and for my wireless devices to be able to connect to the router". That is almost verbatim what she told me. She assured me she knew how to fix the issue...for $50. I have tried several times setting a static IP with no luck, but Im also not sure im inputting the correct Ip's to be able to access the router. Can anyone here help me save a Grant on this problem? My IPConficg/all is copied and pasted below. Thanks for any help in solving this problem.
C:\WINDOWS\system32>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-PTDR4TA
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 6C-F0-49-56-7F-BD
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2604:2d80:4022:0:79b3:21e1:4458:7b22(Preferred)
Lease Obtained. . . . . . . . . . : Saturday, November 18, 2017 10:07:47 PM
Lease Expires . . . . . . . . . . : Saturday, November 25, 2017 9:05:17 PM
Link-local IPv6 Address . . . . . : fe80::15f0:d438:2319:aec1%14(Preferred)
IPv4 Address. . . . . . . . . . . : 50.80.254.105(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, November 18, 2017 10:07:59 PM
Lease Expires . . . . . . . . . . : Wednesday, November 22, 2017 9:05:15 PM
Default Gateway . . . . . . . . . : fe80::217:10ff:fe8d:c1a%14
50.80.254.1
DHCP Server . . . . . . . . . . . : 68.66.76.137
DHCPv6 IAID . . . . . . . . . . . : 40693833
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-7B-A7-71-6C-F0-49-56-7F-BD
DNS Servers . . . . . . . . . . . : 108.166.149.2
108.166.149.3
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Ethernet 2:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : TAP-Windows Adapter V9
Physical Address. . . . . . . . . : 00-FF-AE-C2-BD-D2
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:cae:2d25:cdaf:196(Preferred)
Link-local IPv6 Address . . . . . : fe80::cae:2d25:cdaf:196%11(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 184549376
NetBIOS over Tcpip. . . . . . . . : Disabled
Thanks for your response. You are correct. After talking to the Rep again, it turns out the cause is my ISP. They claim it's the router, but the router is fine. The tech said she will be calling me back tonight, because the two tech support guys at my ISP were clueless, and she will talk with a supervisor, who she has worked with before, as this is a known issue with my ISP and this router modem.. She said they will have to come to the house to do just what you said...unbridge the modem, but if that is something I can do myself, I will look into it. Thanks for your help.
> [...] Here I see a the Genie inteface, but cant do much of anything
What's under the "Administration" menu? (You may not need to do
much.)
That is a public IP address. If your Windows system is getting that,
it suggests that the C3700 is in bridge mode, so that your Windows
system is talking directly to your ISP, not to your (router-mode)
router.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual, and look for "Cable Your Modem
Router to a Router or Gateway" (page 11). You seem to want "Router
Mode (Yes)".
> [...] The "routerlogin.net/com" addrsses show up every time as..."You
> may not be connected to your Router's WiFi network. [...]
Welcome to what may be the worst error message in the world. For an
explanation, try:
https://community.netgear.com/t5/x/x/m-p/1365830
Briefly, the idea is that "[www.]routerlogin.net" should point to
your own router, but that's true only if you use your own router for DNS
name resolution. With the C3700 in bridge mode, you'd be using your
ISP's real-world DNS server, which would take you to that (useless,
misleading) error page.- DocRockkAspirant
