btk55343
Feb 28, 2017Follower
cant logon to cg3000d
Bought a used cg3000d. Connected it directly to pc but cant logon. Reset to factory default and default creds not working. Is there a way for Netgear to format firmware so that I can sign in?
DarrenM
Mar 02, 2017Sr. NETGEAR Moderator
Hello btk55343
Make sure you are holding the reset button down for atleast 10 seconds this should default the unit back.
DarrenM
