kdlp
Mar 31, 2016Aspirant
Can't reset password
Am trying to reset my password and none of the Netgear methods are working. When I try to access the netgar page the username password (admin, password) don't work. When I manually enter my ip address, it can't find it. Now what?
Thanks for any help.
kelly.peres.1@gmail.com
- DarrenMSr. NETGEAR Moderator
Hello kdlp
The only way to reset the password is by doing a factory reset by holding down the reset button on the back with a pin for 10 seconds this should reset it to admin, password.
DarrenM
- kdlpAspirant
I'll give it a try, thx.
kdlp
- kdlpAspirant
I have a hole and a button just below the USB port. I tried holding the button down for 10 seconds and could see no effect when trying to access the sign-in page. I probed the hole with a pin but couldn't feel any button or switch inside. Is it necessary that I restart (power on/off) the router before or after the reset?
kdlp
