yjiang
Mar 04, 2022Aspirant
Capped to 100 Mbps on Wi-Fi
Xfinity 600 Mbps. Confirmed with cable connection to PC and Macbook Air M1.
Netgear C7000.
But Wi-Fi on both 2.4 GHz (600 Mbps) and 5 GHz (1.3 Gbps) can only give around 100 Mbps (80-150 Mbps) to Macbook Air M1.
What Wi-Fi speed should I expect?
You are talking about wifi speeds here?
It might be worth a bit of background reading.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
Have you tested other devices and not just the M1?
Have you simply tried a factory reset and reinstall?
- yjiangAspirant
Reset tried.
iPhone 13 Pro Max Tried.
Still not over 200 Mbps
yjiang wrote:
Reset tried.
That looks low for thatphone.
For comparison, what speeds does this device achieve on different wifi sources?
