schplat
Feb 14, 2026Aspirant
CAX 80 injecting malformed TCP RSTs
I have a CAX80 that appears to be actively interfering with and terminating encrypted TLS connections by injecting malformed TCP Reset (RST) packets. This occurs even with the following disabled: ...
schplat
Feb 15, 2026Aspirant
Oops, meant to reply to you, my reply is below. And seeing if the code blocks clean up:
$ sudo dmesg | grep iwl | grep -m 1 firmware
[ 5.046536] iwlwifi 0000:00:14.3: loaded firmware version 89.df9556fc.0 so-a0-gf-a0-89.ucode op_mode iwlmvm
$ modinfo iwlwifi | grep ^filename
filename: /lib/modules/6.18.7-arch1-1/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko.zst
and
$ sudo lspci -v -s 00:14.3
00:14.3 Network controller: Intel Corporation Alder Lake-P PCH CNVi WiFi (rev 01)
Subsystem: Intel Corporation Dual Band Wi-Fi 6E(802.11ax) AX211 160MHz 2x2 [Garfield Peak]
Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 13
Memory at 618d1d4000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [40] Express Root Complex Integrated Endpoint, IntMsgNum 0
Capabilities: [80] MSI-X: Enable+ Count=16 Masked-
Capabilities: [100] Latency Tolerance Reporting
Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
Feb 15, 2026Guru - Experienced User
What FW version is loaded on the CAX80?
Drivers for adapters up to date? There a driver version?
Which ISP are you connected too?
Happens with a different PC or laptop?
Wireless configuration on the CAX80?
- schplatFeb 15, 2026Aspirant
v5.1.1.8
It's built into the kernel, so the driver versions align with the kernel version. A kernel update is available, but this has been happening for a while, over many previous kernel versions. I can go from 6.18.7 -> 6.18.9, but I would have to dig through kernel change log to see if the drivers have been touched in that time.
$ sudo pacman -Qo /lib/modules/6.18.7-arch1-1/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko.zst /usr/lib/modules/6.18.7-arch1-1/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko.zst is owned by linux 6.18.7.arch1-1If you want to suggest an alternate linux driver, so long as it has DKMS, I should be able to install it no problem.
Xfinity
Difficult to reproduce, as it's only happening against resources I have access to from my work laptop. I can't access the same resources from my PC. I can however, put my laptop on my phone's hotspot, disconnect the phone from WiFI, and the problem goes away.
AX enabled
Smart Connect disabled
2.4GHz enabled
WPA2-PSK [AES]
5GHz enabled (separate SSID)
WPA2-PSK [AES]
