schplat
Feb 14, 2026Aspirant
CAX 80 injecting malformed TCP RSTs
I have a CAX80 that appears to be actively interfering with and terminating encrypted TLS connections by injecting malformed TCP Reset (RST) packets. This occurs even with the following disabled: ...
Feb 17, 2026Guru - Experienced User
Which Ai are you working with and is there a version# for this Ai agent?
And with Protection Engine disabled and the connection reset. Get the connection re-established again and see if this issue persists or changes?
