Riledup1's avatar
Riledup1
Follower
May 20, 2022
CAX 80 no WIFI
just had a brief power outage. have lan internet but no wifi. rebooted 2xs, all lights are white. router login doesn't work either. Thanks in advance.
  • plemans's avatar
    did the wifi on/off button get hit? push and hold it for 2 seconds.
    The routerlogin doesn't work? what happens? Are you able to get to it but not log in?
    How old is it?
  • michaelkenward's avatar
    michaelkenward
    What else is on the network? It is important to start things in the expected order so that each device takes it cues from the components up stream.
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it to connect.
    • Turn on computers and rest of network.
    If that doesn't work, tell us what the modem/gateway is at the head of the queue.
