Tantan1220
Apr 17, 2023Aspirant
CAX 80 Power Light Only On, won’t reset
I have a CAX80 cable modem router that recently stopped working. The modem worked great from July 2021 - August 2022. I disconnected it, and boxed it up when I moved. Then, when I was settled in my ne...
Apr 17, 2023Guru - Experienced User
Try a factory reset with the ISP coax line disconnected. Press the reset button for 10 seconds then release. See if the front LEDS come on and the download LED keeps blinking. Then connect the ISP coax line back to the modem. Then try connecting to the modems web page with a ethernet connected PC at 192.168.1.1 in a web browser.
if all fails, please reach out to a forum moderator to see what your options are:
