Atrocity79
May 29, 2023Tutor
CAX30 - Optimum Internet - Internet Disconnects
Hello. I currently have Optimum Internet in South Texas and using the Netgear CAX30 modem/router. It is now May 29th and about 2 days ago I started to have intermittent internet disconnections. I...
May 29, 2023Guru - Experienced User
The event log and the cable connections page help us to check and see if its a line issue. You can post a screensnip of them back here.
but you can check your line.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
