ErzakAZ
Feb 11, 2026Aspirant
CAX30: Can't connect using WiFi after Netgear Armor trial period ends
I have a fairly new Nighthawk AX6/CAX30 modem/router, using it with Cox, have had it for just over a month. It came with a one month free trial of Netgear Armor. I'd been getting emails for the last ...
ErzakAZ
I just looked on my phone, and it does show randomized MAC under network details (I'm at work and not connected to WiFi), but I did not make any changes to settings either in my phone (or any other device at home: Kindle, Android tablet, Windows PCs) and this is affecting all of my devices. I did try forgetting the profile and re-adding on at least one device, but will try that again.
Feb 11, 2026Guru - Experienced User
What channels are you using on the CAX?
What security mode are you using?
I use channels 1 and 40 and set mixed mode WPA2/WPA3.
