aimpulsive
Sep 28, 2022Tutor
CAX30 Can't edit settings with browser
I can connect to 192.168.1.1 and log in as admin but when I do, using either firefox or chrome, I just see a screen that includes my model number, firmware version number, and nothing else. Doing a r...
Sep 29, 2022Guru - Experienced User
Does it do the same if you log in through the 192.168.100.1 address?
aimpulsive
Sep 29, 2022Tutor
Hi plemans, yes it does the same thing. When I first log in I see this, and then I close the box about using the app and nothing on the bottom half of the screen ever shows up. I also tried using routerlogin.net and it does the same thing.
- FURRYe38Sep 29, 2022Guru - Experienced User
Might try updating FW?
- aimpulsiveSep 29, 2022Tutor
Well, I unplugged the modem/router for 10 mins and plugged it back in. Now it works fine. I had tried rebooting before but never left it unplugged for so long.
Thanks plemans for responding and trying to assist!
