Bradylaura2000's avatar
Jul 19, 2022
CAX30 (Costco) will randomly stop passing traffic for some devices but not all
Random wifi devices lose connectivity intermittently. I know the signal is good because the TV never stops!
  • Noticeable drops: Smart plugs, Blink hub, Roku, iPhone12
  • Seem ok:  LG tv, Firesticks, iPhone SE
I've been reading a bunch about the CAX30 Costco special.  Did I buy a lemon?  (My old CM500 might have been rebooted 1x/year, was I spoiled?)
CAX30 is up to date, small 900 sq ft house, great coverage when working, standard Channels 2.4-auto, 5-153, Guest wifi is disabled. The only "fancy" stuff I'm using is the Smart Connect, a single port forwarded for Plex, and a bonded connection to a NAS.  (unplugged for troubleshooting)
I had Access Control on but with a single laptop blocked, allow new devices. (also turned off for tshooting)  Also in Access Control, over half of my devices don't list a MAC, and multiple are listed multiple times. (might be normal?)
I had to reboot 4x last Friday after my standard Windows 10 laptop started dropping in the middle of meetings.  Meanwhile, I can hear the living room Firestick streaming away.  Usually a single reboot brings everything back, but this weekend it took 2 reboots.  (After initial reboot, I was calling Xfinity for a line test and my dad rebooted it again to be helpful. It fixed it, but I wanted Xfinity to confirm where the issue was but couldn't get to their higher level tech support after it came back up! boo)
If the connection does go down, does the app and/or gui become all but unusable?  (either wired to 192.168.1.1 or the app, both poor)  Repeatedly logs me out for spinning too long.  It's easier to go to Xfinity app to reset it - I don't think I'm losing any logs with a reboot.
My dad said it was acting up a little bit ago - and I did find this "Critical" in the logs.  So I think that's explainable - Is there anything relevant in the "Notice" logs?  I know when I'm forced to reboot, the timestamp rolls back to 1970 like NTP won't update - but I can't tell if it's from before or after the reboot. (I wish I had saved those logs - sorry)
2022-07-19 16:53:49Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:xx:xx:xx:xx:xx;CMTS-MAC=00:01:02:00:01:02;CM-QOS=1.1;CM-VER=3.1;
2022-07-19 16:53:47Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=80:xx:xx:xx:xx:xx;CMTS-MAC=00:01:02:00:01:02;CM-QOS=1.1;CM-VER=3.1;
2022-07-19 16:53:14Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=80:xx:xx:xx:xx:xx;CMTS-MAC=00:01:02:00:01:02;CM-QOS=1.1;CM-VER=3.1;
2022-07-19 16:52:38Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:xx:xx:xx:xx:xx;CMTS-MAC=00:01:02:00:01:02;CM-QOS=1.1;CM-VER=3.1;
2022-07-19 16:52:22Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=80:xx:xx:xx:xx:xx;CMTS-MAC=00:01:02:00:01:02;CM-QOS=1.1;CM-VER=3.1;
2022-07-19 16:51:48Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:xx:xx:xx:xx:xx;CMTS-MAC=00:01:02:00:01:02;CM-QOS=1.1;CM-VER=3.1;
2022-07-19 16:51:36Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:xx:xx:xx:xx:xx;CMTS-MAC=00:01:02:00:01:02;CM-QOS=1.1;CM-VER=3.1;  80:xx:xx:xx:xx:
Should I suck it up and default it or return if I can? Any known issues with any of these "features"?  Does it sound like resources are getting beat up?
Thanks for any thoughts, shared experiences. I want to love this combo box and I hope this isn't standard for NetGear!
