MileHighBurt's avatar
MileHighBurt
CAX30 has to restart multiple times a day
I have the latest firmware and have had no issue in the past with connectivity.  For some reason, after losing power during a storm a few weeks ago, I now have to restart the router every few hours because it just loses internet connectivity.  The network is still active, just no internet.  I tried a factory reset and that did not help.
  • FURRYe38's avatar
    What ISP are you with?
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
    Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Start with removing any amplifiers, signal attenuators, or splitters from the coax.
    From there check the line for kinks, damage, moisture in the line.
    Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
    Be sure to power OFF the modem for 1 minute then back ON.
    https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
    https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
    https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
    • MileHighBurt's avatar
      MileHighBurt
      Cable Information
      Hardware VersionV1.01
      Firmware VersionV2.1.3.10
      Cable Firmware VersionV1.04.05
      Cable Modem Serial Number6PK122WL0222A
      CM certificateInstalled
      CM MAC34:98:B5:8F:DE:38
      LAN Port
      MAC Address34:98:B5:8F:DE:3A
      IP Address/Mask192.168.1.1/255.255.255.0
      DHCPEnabled
      REBOOT
      Internet Port
      MAC Address34:98:B5:8F:DE:39
      IP Address74.139.234.132
      2607:fcc8:bfc0:64:541f:6d3c:d513:a1c2
      ConnectionDHCP
      Mask255.255.224.0
      128
      Default Gateway74.139.224.1
      fe80::201:5cff:fe64:5046
      Domain Name Server209.18.47.63, 209.18.47.61
      2001:1998:f00:1::1, 2001:1998:f00:2::1
      Show Statistics Connection Status
      Wireless Settings (2.4GHz)
      Name (SSID)Spaceballs_TheWIFI!
      RegionUnited States
      ChannelAuto (5)
      ModeUp to 860Mbps
      Wireless APOn
      Broadcast NameOn
      Wi-Fi Protected SetupConfigured
      Wireless Settings (5GHz)
      Smart ConnectENABLED
      Channel149 + 153(P) + 157 + 161
      ModeUp to 1801Mbps
      Using Spectrum
      MileHighBurt
      TimePriorityDescription
      2023-03-26 17:58:50Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
      2023-03-26 17:58:47Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
      2023-03-26 17:58:46Notice (6)TLV-11 - unrecognized OID;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
      2023-03-26 17:58:45Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
      2023-03-26 17:58:45Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:00:33Notice (6)Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
      1970-01-01 00:00:28Critical (3)No Ranging Response received - T3 time-out;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:00:24Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:00:29Critical (3)No Ranging Response received - T3 time-out;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:00:30Critical (3)No Ranging Response received - T3 time-out;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:00:25Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      2023-03-24 18:51:15Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
      2023-03-22 15:17:48Critical (3)No Ranging Response received - T3 time-out;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:02:36Critical (3)No Ranging Response received - T3 time-out;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:02:17Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:00:27Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
