pepbrow's avatar
pepbrow
CAX30 in modem mode not getting IP from ISP
I set "Router Mode" to no in advanced settings. Xfinity shows modem as good to go, but on my end, CAX30 is not getting/picking up an IP.
It's (the device) not Xfinity, so they can't really help. All they can tell me is, the modem looks good to them.
Any suggestions?
  • FURRYe38's avatar
    Which port on the back of the CAX are you using? Port #1 should be used to connect to for a wired PC or 1 external router.
    Power OFF the CAX for 30 seconds then back ON with the wired PC or router connected to port #1...
      • FURRYe38's avatar
        Be sure to use good quality LAN cable between the modem and router. CAT6 is recommended.
