Bricked1234
Feb 23, 2023Aspirant
CAX30 RMA shipment costs
Hi all, Has anyone had luck with cax30 RMA and return shipment cost . Phone tech support said I needed to pay to ship old one back. I do not accept this as this is 100% error out of the users hands...
Feb 23, 2023Guru - Experienced User
I would reach out to a forum moderator for additional help on this.
Bricked1234 wrote:
Hi all,
Has anyone had luck with cax30 RMA and return shipment cost . Phone tech support said I needed to pay to ship old one back. I do not accept this as this is 100% error out of the users hands and matter of fact resetting the router seems stops you from using the Ethernet solution and that was the first thing they recommend to me. I'm willing to continue to use Netgear as previous experiences have been okay but if they are going to make me pay out of pocket for their firmware issue that does not sit well with me.
- Bricked1234Feb 23, 2023AspirantI have sent a pm. Thank you
- FURRYe38Feb 23, 2023Guru - Experienced User
Something to try in meantime if you can:
- Bricked1234Feb 23, 2023AspirantThanks I looked into it earlier. Guess the 2 questions I have of you might now. When I plug in the router before pressing enter the power button doesn't turn orange so I just assume to press enter soon as I plug it in. 2nd the downloaded file is a .bin. Should I rename it to chk?
