Washautumnstar
Aug 02, 2021Aspirant
CAX30 Slow Wifi
I am at my wits end and hoping someone has some answers.
I have been having issues with slow internet speeds. When my package was for 400mbps, I was getting 250, I thought it wasn't too bad. Recently upgraded and now am supposed to be getting 800, I'm still at max of 250.
So I had my ISP (Comcast) come out and do an inspection, they fixed some spots but also said I needed new hardware. So I upgraded to the nighthawk CAX30 which should get wifi speeds up to 2700, Ethernet is great 930 (out of 800) so it's not Comcast's fault, but wifi i am stiiiilll only at 250mpbs .
I was on the phone for 4 hours with Netgear support, changing channels, and mtu, and factory reset, still nothing fixed. And when they ran out of ideas they kept trying to say I needed to wait, first 2-3 hours (after already being on for 4) then tried to say 24 hours, they refuse to admit there is something wrong with the device, or transfer me to someone who has any other ideas. So I am turning to the forums..
Some things I've gone through:
Switching channels for both 2.4 and 5G
Lowering the MTU
Turning off Smart connect
Factory Reset
Double checked firmware is the latest
Buying a new Wifi card (not sure I understand these but link signal on old said 433/433, so thought it was capping? New adapter is 1300/1300)
Made sure drivers were up to date
TLDR: brand new modem/router. Ethernet fine, wifi speeds not getting above 250mbps, should be 800 please help.
Lowering the MTU
Factory Reset
What brand and model wifi device are you using to speed test with? Some AC mode devices have limitations on what they can actually speed test up too. Most max out at around 400-500Mpbs on 5Ghz AC. Even at 1300Mpbs though you should see near 600-700Mpbs.
What band does the device connecte too? 2.4 or 5Ghz?What speed test app are you using to speed test with? Ooklas installable speed test app works well.
- WashautumnstarAspirantI have tested with multiple devices on multiple speed test sites: desktop/2 laptops/android smartphone. Ookla, Xfinity, and Netgear speed sites. All of these were on my 5G network
I also thought that the cards I had should have at least gotten to 400. So I got the new adapter, which is an Edimax EW-7833UAC AC1750 which as mentioned, says it should be able to get speeds up to 1300. But I'm still stuck around 250- FURRYe38Guru - Experienced User
Washautumnstar wrote:
I have tested with multiple devices on multiple speed test sites: desktop/2 laptops/android smartphone. Ookla, Xfinity, and Netgear speed sites. All of these were on my 5G network< is this the 5G wireless on the CAX or cell service?
I also thought that the cards I had should have at least gotten to 400. So I got the new adapter, which is an Edimax EW-7833UAC AC1750 which as mentioned, says it should be able to get speeds up to 1300. Wifi bandwidth will never see 1300Mbps bandwidth download speeds on 5Ghz AC with your adapter.
Its rating is:Data Rate
11a: 6/ 9/ 12/ 24/ 36/ 48/ 54Mbps
11b: 1/ 2/ 5.5/ 11Mbps
11g: 6/ 9/ 12/ 24/ 36/ 48/ 54Mbps
11n (20MHz): MCS0-15 (up to 223Mbps)
11n (40MHz): MCS0-15 (up to 450Mbps)
11ac (80MHz): MCS0-9 (up to 1300Mbps)FYI, These are DATA Connection RATES only. Meaning that its the connection rate seen between the this adapter and host wifi router. This is NOT actual bandwidth download speeds. This differs from Data Rate. https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
I would agree though that if the adapter is connected at 1300Mpbs, it should be seeing around 500Mpbs on 5Ghz with the CAX.
Is Smart Connect enabled on the CAX?
What FW is loaded on the CAX?
And be sure the USB adapter is connected to a USB 3.0 port on the PC?
