antisharper's avatar
antisharper
Follower
May 21, 2023
CAX30 unable to Backup Settings
CAX30 - FW 1.4.11.2
Cable Modem / Gateway is working correctly, but I'm unable to use WEB UP to "Back Up" my current settings.
"Back Up" button look like it's being selected (color changes) when I select it and click... but no file is generated back to my browser. Didn't have this problem back in Nov 2022, that the last backup I have of my settings.
I've tried it in:
   Windows 10 - Chrome, Firefox, Edge;
   Linux - Chrome, Firefox;
   MacOS - Safari, Chrome. Firefox
Any ideas what's going on or any backdoors to copy the current config that can be "Restored" via the Web UI?
  • FURRYe38's avatar
    Has all browser caches been cleared out before going into the modems web page?
    Any browser security add-ons are disabled as well?
  • I had the same problem, so I looked through the webpage source. I entered the URL for the Backup page directly in the browser bar -- https://192.168.1.1/BackupSettings.php -- and when I clicked the Backup button, I immediately got a Windows Save As dialog. However, Firefox then blocked downloading the file, because the file is sent over http, while the webpage itself is https, but I clicked the warning and then clicked Allow Download, and it came through.
    I suspect the hangup is a browser security feature blocking Javascript from accessing the file chooser within a frame and/or a mix of http and https on the same page.
    Unfortunately, the backup data is binary, and there is no way to convert it to plain text.
    • FURRYe38's avatar
      Have you tried MS Edge or Opera to see if same thing happens?
      What FW version are you using on your CAX30?
