zachya's avatar
zachya
Tutor
Nov 18, 2025
CAX30 UPnP error with multiple Xboxs
Setup: I have a CAX30 acting as modem and router. UPnP IS toggled on in the gateway utility. Verified latest firmware installed. 2 (sometimes more) xboxs connected via wireless.   The issue is each...
  • FURRYe38's avatar
    If you assigned a static IP address and manual port number, try disabling uPnP on the CAX30.
