zachya
Nov 18, 2025Tutor
CAX30 UPnP error with multiple Xboxs
Setup: I have a CAX30 acting as modem and router. UPnP IS toggled on in the gateway utility. Verified latest firmware installed. 2 (sometimes more) xboxs connected via wireless. The issue is each...
- Nov 18, 2025
If you assigned a static IP address and manual port number, try disabling uPnP on the CAX30.
zachya
Nov 18, 2025Tutor
Firmware V2.2.4.2
ISP is Cox (hate em, but they're they fastest in town)
I've scoured the utility for NAT filter settings and could not locate. I have attached a few sceenshots from said utility.
I have previously assigned each xbox a static IP and manual port number, verifying that it is forwarded correctly in the utility.
Nov 18, 2025Guru - Experienced User
- zachyaNov 18, 2025Tutor
Holy crap so far that's working! I never would have thought to turn uPnP off after assigning manual numbers.
I'll mark that as the solution for now, and will update if anything else changes. IE "no news is good news" if ya don't hear from me.
Thanks again!!!!
- FURRYe38Nov 18, 2025Guru - Experienced User
Glad that worked. I wish NG had included NAT Filter on there gateways. They do on there routers and that works for having more than one game console online at the same time.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
