kkola's avatar
kkola
CAX30s Xfinity 1G speed issues
I recently within the past month purchased a CAX30. At the time I was running Xfinitys 800 speed. Through ethernet I was getting 920ish mbps and everything was good. I recently upgraded to 1G speeds and havent been able to get anything over 840 since. I'm not sure why all the sudden im getting lower speeds than I was when i was on 800mbps plan but I was wondering if someone could help me with this or if anyone else has ran into the same issues.
    • kkola's avatar
      kkola
      This is on a cat 8 ethernet wired. Firmware version 1.4.12.2. I had upgraded firmware to the latest when i first got the CAX30 but the speeds were terrible so I came back down to 1.4.12.2 and hadn't had any issues until today
      TimePriorityDescription
      2023-12-07 18:14:56Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;
      2023-12-07 17:43:57Error (4)SW upgrade Failed before download -TFTP Max Retry Exceeded
      2023-12-07 17:43:27Notice (6)SW Download INIT - Via Config file d11_m_cax30_extremepro_c01.cm
      2023-12-07 17:43:16Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile:
      1970-01-01 00:00:41Notice (6)Honoring MDD; IP provisioning mode = IPv6
      1970-01-01 00:00:35Critical (3)No Ranging Response received - T3 time-out;CM-
      1970-01-01 00:00:29Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;
      2023-12-07 17:41:28Critical (3)Resetting the cable modem due to docsDevResetNow
      1970-01-01 00:00:30Critical (3)No Ranging Response received - T3 time-out
      1970-01-01 00:00:24Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;
      1970-01-01 00:00:29Critical (3)No Ranging Response received - T3 time-out;CM-
      2023-12-07 16:23:15Critical (3)Resetting the cable modem due to docsDevResetNow
      Frequency start Value
      This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
      Starting Frequency
      <tabindex=-1>Startup Procedure</tabindex=-1>
      ProcedureStatusComment
      Acquire Downstream Channel705000000 HzLocked
      Connectivity StateOKRegistration Complete
      Boot StateOKOperational
      SecurityEnabledBPI+
      IP Provisioning ModeHonor MDDIPv6 only
      <tabindex=-1>Downstream Bonded Channels</tabindex=-1>
      ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectabables
      1Locked256 QAM37705000000 Hz-4.-8 dBmV38.0 dB183616172984
      2Locked256 QAM10531000000 Hz-3.-3 dBmV41.4 dB00
      3Locked256 QAM11537000000 Hz-3.-4 dBmV41.5 dB00
      4Locked256 QAM12543000000 Hz-2.-5 dBmV42.0 dB00
      5Locked256 QAM13549000000 Hz-2.-8 dBmV42.0 dB00
      6Locked256 QAM14555000000 Hz-3.-1 dBmV42.1 dB00
      7Locked256 QAM15561000000 Hz-2.-2 dBmV42.5 dB00
      8Locked256 QAM16579000000 Hz-2.-4 dBmV42.7 dB00
      9Locked256 QAM17585000000 Hz-2.-3 dBmV42.7 dB00
      10Locked256 QAM18591000000 Hz-3.-6 dBmV42.1 dB00
      11Locked256 QAM19597000000 Hz-3.-8 dBmV42.1 dB00
      12Locked256 QAM20603000000 Hz-3.-9 dBmV41.8 dB00
      13Locked256 QAM21609000000 Hz-4.-8 dBmV41.4 dB00
      14Locked256 QAM22615000000 Hz-4.-7 dBmV41.2 dB00
      15Locked256 QAM23621000000 Hz-3.-6 dBmV41.3 dB00
      16Locked256 QAM24627000000 Hz-4.0 dBmV40.8 dB00
      17Locked256 QAM25633000000 Hz-4.-4 dBmV40.5 dB00
      18Locked256 QAM26639000000 Hz-3.-8 dBmV40.3 dB00
      19Locked256 QAM27645000000 Hz-3.-7 dBmV39.9 dB00
      20Locked256 QAM28651000000 Hz-3.-7 dBmV39.9 dB00
      21Locked256 QAM29657000000 Hz-3.0 dBmV39.9 dB00
      22Locked256 QAM30663000000 Hz-3.0 dBmV39.8 dB00
      23Locked256 QAM31669000000 Hz-3.-6 dBmV39.6 dB00
      24Locked256 QAM32675000000 Hz-3.-5 dBmV39.4 dB00
      25Locked256 QAM33681000000 Hz-3.-8 dBmV39.6 dB00
      26Locked256 QAM34687000000 Hz-4.-9 dBmV39.3 dB00
      27Locked256 QAM35693000000 Hz-5.-1 dBmV39.2 dB00
      28Locked256 QAM36699000000 Hz-4.-6 dBmV39.1 dB00
      29Locked256 QAM38711000000 Hz-4.-9 dBmV38.9 dB4647449181
      30Locked256 QAM39717000000 Hz-4.-6 dBmV39.0 dB00
      31Locked256 QAM40723000000 Hz-4.-7 dBmV39.0 dB00
      32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
      <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
      ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
      1LockedATDMA15120 Ksym/sec35600000 Hz55.3 dBmV
      2LockedATDMA25120 Ksym/sec29200000 Hz54.5 dBmV
      3LockedATDMA35120 Ksym/sec22800000 Hz53.0 dBmV
      4LockedATDMA45120 Ksym/sec16400000 Hz51.8 dBmV
      5LockedATDMA55120 Ksym/sec39600000 Hz52.8 dBmV
      6Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      7Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      8Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      <tabindex=-1>Downstream OFDM Channels</tabindex=-1>
      ChannelChannel IDIndicatorSubcarrier Zero FrequencyActive Subcarrier Number RangeTotal CodewordsUncorrectable Codewords
      141Non-Primary671.6 MHz1108 ~ 2987109751230
      20Other0 MHz0 ~ 000
      <tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
      ChannelUpstreamIsMutedRanging StatusSubcarrier Zero FrequencyActive Subcarrier Number RangeSymbols Per FrameTx Power
      1 Other0 MHz0 ~ 000 dBmV
      2 Other0 MHz0 ~ 000 dBmV
