SunnahWay
Feb 08, 2026Aspirant
CAX80 - Internet Outage Reset
It happened a few of times I had a disruption in my internet signal. The latest with an Internet outage. My ISP is COX and after the outage was over my signal coming from then was good. But after mul...
Mar 11, 2026Guru - Experienced User
Any progress on this?
SunnahWay wrote:It happened a few of times I had a disruption in my internet signal. The latest with an Internet outage. My ISP is COX and after the outage was over my signal coming from then was good. But after multiple resets and troubleshooting COX could not figure it out. I logged in my router and confirmed all the settings were good. Ultimately, I rest the router and established it again which made by connection work.
I just read this post which I think is describing the same thing.
https://community.netgear.com/discussions/home-cable-modems-routers/cax80-complete-reset-after-losing-internet-or-power/2231124
Is that a normal procedure? Has anyone else experienced this? Did I do the right thing or should I do something else instead of reseting the router?
